Activity › Forums › Adobe Premiere Pro › RED footage mono audio playing only out of left speaker
  • RED footage mono audio playing only out of left speaker
    Posted by Brandon Adams on March 23, 2012 at 6:00 pm
    I’m editing some RED footage and I’m having trouble with the audio. Playing a clip in the Source window: the audio is centered. Putting that clip into a sequence: the mono track only plays out of the left speaker.
    I can’t apply a fill left because it’s not a stereo track. I can’t change the map audio settings for a clip (greyed out).
    Anyone know how I can get the mono track to play as mono (centered) rather than only left in the sequence?
    Thanks!!
    -Brandon
    John-michael Seng-wheeler replied 14 years, 6 months ago 6 Members · 6 Replies
  • Chris Borjis
    March 23, 2012 at 6:22 pm
    if your in need of a “workaround” export the audio,
    bring into audition and make it stereo, then bring back.
    not sure it’s what you really want, but a workaround
    if you do.
  • Angelo Lorenzo
    March 23, 2012 at 6:25 pm
    I could be totally wrong, but I believe you need to remove it from all sequences before you can change the speaker assignment, or change it to “mono as stereo”.
  • Tom Daigon
    March 23, 2012 at 7:24 pm
    You are correct Angelo. You must remove it from the sequence before you can modify it.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Tom Daigon
    March 23, 2012 at 7:30 pm
    Or you can use the appropriate Audio Effect (Fill Left or Fill Right) to send mono out both tracks WITHOUT modifying the clip , if it is more convenient.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Lance Bachelder
    March 24, 2012 at 7:08 am
    Did you check the mixer? Is the audio panned?
    Lance Bachelder
    Writer, Editor, Director
    Irvine, California
  • John-michael Seng-wheeler
    March 27, 2012 at 12:56 am
    Another possibility is that the Master is set to 16 Channel.
