Activity Forums DaVinci Resolve Red Epic Green screen footage
  • Red Epic Green screen footage
    Posted by Andrew Smith on December 8, 2012 at 4:13 pm
    I have a project with 5k Epic footage all green screen and I want to make sure my workflow is correct.
    The AE artist doing the keying wants to get back 5k tiff sequences from me which shouldn’t be a problem for my system in that I have rendered 5k ProRes444 in the past, but in terms of ‘best practices’ I just want to make sure I do the grade correctly.
    Working in a 1080p 23.98 project:
    As a starting point for grading I was going to set the R3D settings to:
    Color Science: 2
    Color Space: REDcolor3
    Gamma Curve: REDlogfilm
    I will probably look to see first what the footage looks like just on camera metadata vs. REDcolor3/REDgamma3 just to see if its a decent starting point on either or not but usually I like to start with the above mentioned log settings so I can just have more control over the starting point.
    If I decide to do REDlogfilm my first node will be a slight s-curve to get it from Log to something to grade with, followed by a balance node after as a starting point. I was then going to do a key of the green-screen background and desaturate completely in order to have an unbiased grade to work with. After this node I might have a further balance node if need be followed by any secondaries for clothing or skin tone if needed. After grading i would then turn off the desat node for the green screen and render out 5k tiffs for the AE artist to key and composite with.
    I am curious to get some feedback from people about whether or not this is an advisable workflow or not, and if there is anything I am missing.
    Looking forward to your feedback!
    cheers
    andrew
    Andrew Smith replied 13 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
