Activity › Forums › Adobe Premiere Pro › Red Epic footage in Premiere CS5.5.1
  • Red Epic footage in Premiere CS5.5.1
    Posted by Anthony Bernard on November 1, 2011 at 7:40 pm
    I am having a problem importing Red Epic footage into Premiere Pro CS5.5.1. I keep getting the unsupported format/damaged file error. I checked them in RedCineX and they play fine. I have done a little research and it looks like up until 5.5.1 you needed a separate plugin from Adobe to import Epic footage. Since I have the right version I figured things would be fine, but they are not. I am going to try and install the plug in anyways and see what happens, but has anyone else had this problem?
    Anthony Bernard replied 14 years, 11 months ago 3 Members · 12 Replies
  • 12 Replies
  • Anthony Bernard
    November 1, 2011 at 8:39 pm
    I have installed the importer. I can now import the footage. I have connected the r3d files with the editors edl (as I am just doing color correction) and all the connected files go from red to yellow in the time line. All the transitions are red, but when I try to render anything I get “Error compiling movie. Unknown error.” It doesnt shut down or freeze…It just keeps giving me that error every time I try and render anything.
    Any help is greatly appreciated.
  • Tom Daigon
    November 1, 2011 at 9:59 pm
    Heres some info about render lines and their meaning. Its different from FCP.
    https://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-green-render-bars.html#comments
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Anthony Bernard
    November 1, 2011 at 10:31 pm
    Yes I understand the various render bars. My problem is that when I try to render anything at all (whether I do shift+enter or just enter). When I try to export I get a message saying “Offline material is present in this export and will be encoded using the offline media graphic”. I export and it exports fine though…think its related to my render error?
  • Tom Daigon
    November 1, 2011 at 10:44 pm
    So when you want to render your timeline, you get an error message and it wont render the timeline.
    And when you export, you get another error message, but it exports the sequence just fine.
    Am I understanding your situation correctly?
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Anthony Bernard
    November 1, 2011 at 10:46 pm
    Yep. You got it.
  • Tom Daigon
    November 1, 2011 at 10:51 pm
    Well, I would suggest a call to Adobe Tech Support. Its free and eventually you should get the answer you want. Ask for Vinay. I have found him to be very knowledgeable and cool to troubleshoot with.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Anthony Bernard
    November 1, 2011 at 11:08 pm
    Well I may just do that. Thanks for the contact Tom!
  • Tom Daigon
    November 1, 2011 at 11:14 pm
    You’re very welcome, Anthony!
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Anthony Bernard
    November 3, 2011 at 2:21 am
    Ok. So now I have the ability to render the r3d files (I think the recent premiere update had some thing to do with it), but after I rendered my aspect ratio changed and I have black bars top and bottom now…anyone have any thoughts?
  • Tim Kolb
    November 3, 2011 at 12:34 pm
    What are the specs for the media vs the spec for the sequence?
    I wonder if there is a framesize mismatch?
    Are you using an Adobe RED preset sequence?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
