Activity › Forums › Apple Final Cut Pro Legacy › Red Epic and FCP workflow having transcoded ProRes offlines outside of FCP
Jeremy Garchow replied 14 years, 5 months ago 4 Members · 26 Replies
Brandon Mcfarland
April 10, 2012 at 11:51 pmHere is the entire process thus far:
1. Ingest footage using RCX Pro to ProRes proxies.
2. Edit in FCP.
3. Export XML > import to RCX Pro. (All media is reconnected fine and things going smoothly so far)
4. Grade Timeline in RCX Pro.
5. Attempt to export a folder of media + correlating XML from RCX Pro in order to finish the big batch of short timelines that are sitting in FCP waiting for this process to be figured out…Step 5 generates a folder of media that all looks great, but no XML anywhere.
Jeremy Garchow
April 11, 2012 at 12:00 amI’m not next to RCX at the moment, but in the export dialogue, you need to choose ‘sequence’.
I’ll get to a computer and direct you to the exact place.
Jeremy
Jeremy Garchow
April 11, 2012 at 12:30 amIn the export presets window, make sure
“Export: Timeline (separate clips)” is selected. -
Brandon Mcfarland
April 11, 2012 at 12:48 amThat did it. Thanks Jeremy. That is so strange that it sees a timeline in the bin and knows to make individual clips with the setting chosen, but won’t make an XML for the trimmed media that it transcodes in that same batch.
Jeremy Garchow
April 11, 2012 at 12:55 amYes, it needs to be done in a specific order for FCP.
You can always use FCPReconnect, as FCP itself isn’t smart enough.
https://www.videotoolshed.com/product/41/fcpreconnect
It’s handy if you have already rendered, don’t have a Rocket and don’t have time to rerender.
Jeremy
