Activity Forums Boris FX Red engine MP4 import
  • Red engine MP4 import
    Posted by Mark Rothman on January 6, 2010 at 3:36 pm
    The Red 4.3 Premiere plugin seems to work fine with .mp4 files, but the files don’t show up when trying to import them directly into the Red 4.3 engine. I’ve tried renaming them with a .mov or .mpg extension but no go.
    Is there a workaround? I have 1733 .mp4 files so re-encoding isn’t an option. I’m in WinXP.
    Thanks.
    Matt Mullen replied 16 years, 8 months ago 2 Members · 8 Replies
  • 8 Replies
  • Matt Mullen
    January 6, 2010 at 4:31 pm
    They don’t show up? Does it act as if they import?
    Could you send me one of the file I’ll give it a test. mattm@borisfx.com
  • Mark Rothman
    January 11, 2010 at 4:22 pm
    Matt, I sent you an MP4 sample. Did you get it?
  • Matt Mullen
    January 11, 2010 at 4:34 pm
    Yes I did, sorry.
    I am able to import and cut the video into a project.
    Make sure on the import screen you change files of type to “all files”.
  • Mark Rothman
    January 14, 2010 at 6:27 pm
    Matt, with “all files” checked I can see and import my mp4 files … but they won’t play. I sent you another file to see if they play for you.
    Thanks.
  • Matt Mullen
    January 14, 2010 at 7:01 pm
    When you say it doesn’t play what do you mean? Is it just a still frame?
    I have not received any files from you.
    -Matt
  • Mark Rothman
    January 16, 2010 at 1:11 pm
    I’m not sure if it’s imported as a still, but it’s definitely motion-free. I’ve sent another sample.
    Thanks.
  • Mark Rothman
    January 19, 2010 at 6:35 pm
    Matt, did you find out if there’s any chance of getting Red support for H.264-encoded mp4 files?
  • Matt Mullen
    January 19, 2010 at 7:30 pm
    Mark, sorry for the delay.
    It’s a pretty reasonable request, I’m just not sure right now what an ETA would be or if it would be included on Red 4.
    I’ll keep you posted as soon as I hear something.
    Unfortunately for the time being you will have to convert MP4’s to another file type.
