  • Posted by Joe Huggins on May 20, 2010 at 3:39 pm
    This is a Red/Scratch/Cinematools workflow question.
    We want to create dailies from Scratch in a real-time output to a FCP ProRes Capture. Scratch can make an ALE but FCP will not read the Source TC in a Cinema Tools Database. How can we match a ProRes offline back to Source code on the Red files for final conform? (This works on Avid since it will read the ALE Source code but not FCP).
    Any ideas?
    Joe
    Thanks, Film Joe
    Joe Huggins replied 16 years, 4 months ago 2 Members · 2 Replies
  • Doug Beal
    May 20, 2010 at 5:03 pm
    In FCP modify TC
    In Scratch we treat this as an offline online situation coming back to scratch for final output to uncompressed v210, from an FCP EDL
    that being said, in the output from scratch in “Guides” turn on source TC/TC. Place this in the letterbox area of picture. If you shot Red 2:1 you’ll have a narrow band at the top & bottom of picture if you do a “fit width” in the framing controls.
    The clip name and source code as well as Scratch Construct TC is now burned in to the picture and can be cropped in FCP to show nothing.
    If you come back to scratch for finishing (Shot repos / framing blemish fixes Etc are incredible in scratch) make sure your ref Movie has the BITC. makes conform a snap if any EDL hink occurs. You can immediately see what shot you need.
    be aware that any speed ramps in FCP work by using a frame count. If you do any of this the entire shot needs to be output from scratch in order to do the finish in FCP from a final grade out of scratch.
    These are best approached in their own constructs in scratch since it does not do speed ramps to match FCP ramps. Straight up speed changes are fine in scratch but not ramps.
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Joe Huggins
    May 25, 2010 at 8:52 pm
    Doug, Sorry for the delay I was out of the office.
    Yes, we can burn in code and manually conform. That is too time costly. I need an EDL file that will auto conform to source TC after an FCP edit. Did I miss something in your reply? How do we get FCP to take source code from an ALE made in Scratch when we output in realtime to ProRes for offline?
    Thanks, Film Joe
