Activity Forums Adobe Premiere Pro RED Color Correct
  • RED Color Correct
    Posted by Casey Baugess on October 2, 2012 at 6:03 pm
    I’m working with .R3D footage in Premiere CS6. When you color correct a clip using ‘Source Settings’, it applies those changes to the entire clip. However, some parts of the same clip need different settings. Is there a way to edit the source settings to only a specific part of the clip, or do you have to import the clip again to make different changes?
    Thanks in advance!
    -Casey
    Kevin Monahan replied 13 years, 11 months ago 2 Members · 1 Reply
