Activity › Forums › Apple Final Cut Pro Legacy › Red bar problem in the fourth and afterwards video tracks – FCP
  • Red bar problem in the fourth and afterwards video tracks – FCP
    Posted by Mahmoud Salimi on July 1, 2010 at 6:27 am
    I’m working with FCP7 on a MacBook Pro (2.4 Ghz and 4GB RAM). The footage I am editing is shot with 5D and 7D. I am running the footage from a USB hard drive. After dragging and dropping the footage to the three video tracks, I get a red bar the fourth track. I changed the codec and some sittings in the timeline, but didnt succeed to solve the problem. I will appreciate your help.
    Sequence sittings:
    Frame size: 1920×1080 (HDTV 1080i)
    Pixel Aspect Ratio: Square
    Editing Timebase: 23.98
    Compressor: H.264
    Best,
    Salimi
    Ben Holmes replied 16 years, 2 months ago 2 Members · 1 Reply
  • Ben Holmes
    July 1, 2010 at 1:42 pm
    Hi Salimi
    First – FCP is not designed or optimised for editing in H.264. You should transcode the footage to ProRes. You can get a free plugin from Canon that allows you to import and transcode, or spend $50 on Magic Bullet’s Grinder if you prefer to edit while you import.
    Second – Never edit from a USB hard drive – they do not transfer data in a way that is friendly for video, and you will never get smooth playback. Invest in a firewire drive – you will need it when you go to ProRes anyway, so get a FW800 drive if you have that port on your laptop.
    I have no idea how your laptop could even play 3 streams of H.264 – To get a red bar on the fourth is not suprising.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
