Activity › Forums › Panasonic Cameras › Red and Blue Bleed
Red and Blue Bleed
Posted by Dana Lavoie on October 4, 2007 at 9:20 pmi have a HVX-200 and when i shoot MINI DV the reds and blues bleed in hight contras situations and low lighting. I Don’t know if this is because of subsampling or the HVX?
Noah Kadner replied 18 years, 11 months ago 2 Members · 5 Replies -
Noah Kadner
October 5, 2007 at 12:25 amPost some stills so we can see what’s happening. DV-NTSC is not exactly the widest chroma range you can have in this world.
-Noah
Unlock the secrets of the DVX100, Apple Color and now the HVX200!
https://www.callboxlive.com -
Dana Lavoie
October 5, 2007 at 2:45 pmHere is a screen grab of the red bleeding and blocky shadows
https://s236.photobucket.com/albums/ff141/lavoie_24/?action=view¤t=Picture2.png
Noah Kadner
October 5, 2007 at 3:03 pmYup that’s pretty normal. You’ll be hard pressed to find a camera in the prosumer world that won’t show antialiasing on high contrast,sharp edges and especially red. You might try adding a promist filter in front of the lens or turning down your edge detail a little. Also a chroma resampler such as Graeme Nattress’ G-Nicer can help a bit with the edges. Another good call is avoid high frequency patterns and bright red in your wardrobe choices.
Noah
Dana Lavoie
October 5, 2007 at 3:21 pmThanks Noah
“Also a chroma resampler such as Graeme Nattress’ G-Nicer can help a bit with the edges.”
what is a Graeme Nattress’ G-Nicer
Noah Kadner
October 5, 2007 at 6:01 pmG-Nicer is a chroma upsampling plugin for FCP:
https://www.nattress.com/Products/filmeffects/filmeffects.htm
-Noah
