Activity › Forums › Avid Media Composer › RED AMA plugin doesn’t work
  • RED AMA plugin doesn’t work
    Posted by Nele Mertens on July 27, 2020 at 3:58 pm
    I have Avid Media Composer 8.5.2 and I’m trying to link to R3D files. I downloaded the plugin from their website (8.5.2 wasn’t listed, so I tried both the recommended version for 8.5.1 as the one for 8.6). The plugin shows up in my Link window, so I select it instead of autodetect and then I select the R3D file, but it doesn’t want to link. I’ve also tried selecting the RDC folder as well as the RDM folder, and it doesn’t want to know.
    I then tried to install several other versions of the plugin, including the latest one and the oldest one. Every time I try a new version of the plugin, I delete the .avx file from the AMA folder in AVX2_Plug-ins, then I install the new plugin and I restart Avid.
    No matter which plugin I try, none of them are working. I don’t know what I’m doing wrong. Can someone help? Many thanks in advance!!88
    Monica Harmon replied 5 years, 11 months ago 3 Members · 10 Replies
  • 10 Replies
  • Michael Phillips
    July 27, 2020 at 5:57 pm
    Have you tried linking directly to the .R3D itself?
    Michael
  • Nele Mertens
    July 27, 2020 at 6:03 pm
    Hi Michael,
    Thanks for replying to my post.
    Yes, I’ve tried selecting the R3D file itself, Avid gives an error message with a link to the AMA plugin website – even though I know the correct plugin has been installed.
    I’m now starting to think that perhaps these specific R3D files are not supported by the plugin version I need for Avid 8.5.2. Perhaps it is time to upgrade :/
    I’m currently trying to export the files as MXF files from Redcine-X, but that isn’t working either – the transcode usually stops at 43% for some reason.
    Any more suggestions? I’ll try anything at this point!
    Nele
  • Michael Phillips
    July 27, 2020 at 6:22 pm
    Did you check to make sure there were no illegal characters anywhere in the link path like a folder somewhere that uses a / for a date?
    Michael
  • Nele Mertens
    July 27, 2020 at 6:28 pm
    Yes, I’ve checked the file path and it seemed fine – but to make sure that wasn’t an issue, I’ve copied an RDC folder to the root of the drive, and that didn’t work either.
    Thanks 🙂
  • Michael Phillips
    July 27, 2020 at 6:52 pm
    It’s strange that Redcine X Pro did not complete the transcode and makes me wonder if there is something wrong with this file. Do all the files behave this same way?
    Michael
  • Nele Mertens
    July 27, 2020 at 7:36 pm
    Yes, only the very short files finish exporting, all the big ones just stop around 30%.
    At the moment I’m exporting again, having changed the Debayer settings from Full to 1/8th, and not only does that speed up the process of exporting dramatically, the exports also don’t seem to stall anymore.
    It’s not ideal, but at least I will be able to start editing some time tomorrow!
    Still strange that I can’t AMA-link, that would make everything (including the online) so much easier!
  • Michael Phillips
    July 27, 2020 at 7:50 pm
    for editorial only, I tend to do 1/2 good or 1/2 – as you noticed it’s faster and you’ll have plenty of resolution to make editing decisions –
    Michael
  • Nele Mertens
    July 27, 2020 at 9:55 pm
    I can’t believe it, Redcine-X crashed.. The universe seems against me ever editing this project XD
    The software is REDCINE-X PRO 52, I downloaded it from the Red website today – should I be using something else?
    Most of the advice I’ve found online said I should transcode to Avid DNx36 – however that’s not an option, after selecting ‘Avid AAF&MXF’ I can only choose between LB, SQ, HQ and HQX.
  • Nele Mertens
    July 27, 2020 at 10:06 pm
    Actually, looks like I’ve run out of space (facepalm) – rookie mistake!
  • Monica Harmon
    October 9, 2020 at 2:23 am
