Activity Forums Boris FX RED 5.5 default window
  • RED 5.5 default window
    Posted by Kuhnen Brown on December 23, 2014 at 1:38 am
    Whether I boot up the stand alone RED, or drop the RED filter onto a clip on the Premiere Pro timeline, RED always opens with the Library Browser window active. I would like to have RED open with the Composite window open/active. Window/Workspace is set to Standard. I have a custom workspace with the Library Browser closed, yet the Library Browner still opens on boot up. Is there a preference file I can trash?
    Kuhnen
    RED 5.5.3
    Host: Premiere Pro CC 2014
    OS X 10.9.5
    Bart Molen replied 11 years, 6 months ago 3 Members · 3 Replies
  • Jon Kozenko
    December 23, 2014 at 4:26 pm
    Kuhnen,
    On OSX 10.9.5, there are actually two preferences files you are likely to find. The first one would simply be the ‘Boris RED 5 Preferences’, the other would be named “com.borisfx.app.Boris RED.plist”. With RED (and any NLE’s you have installed) closed, delete these two files. You can find them here –
    Macintosh HD :: Users :: [ Current User/Home ] :: Library** :: Preferences
    ** – Note that this Library folder is hidden by default on OSX 10.9 – to access it, you would either need to use the Go menu in the Finder, or enable view of hidden objects.
    Jon
  • Kuhnen Brown
    December 23, 2014 at 9:06 pm
    Thanks Jon. That works!
    Kuhnen Brown
    InterMountain Digital
    Oregon
  • Bart Molen
    March 21, 2015 at 9:48 am
    Can this be done with Graffiti, I cant find the files?
    https://www.gripps.net/
    https://www.youtube.com/user/gripps2211?feature=mhee
