Activity › Forums › Boris FX › RED 5.3 ( 64bits ) and genarts sapphire After Effects 7 ( 7 through 7.03 )
  • RED 5.3 ( 64bits ) and genarts sapphire After Effects 7 ( 7 through 7.03 )
    Posted by Wilfried Van on August 22, 2013 at 7:55 am
    Apparently the new genarts sapphire After Effects version 7 crashes
    Boris RED 5.3 when simply trying to add an effect of genarts sapphire 7 .
    version 6 of genarts sapphire After Effects worked fine as plug-in of Boris RED 5.3 ( not using presets of genarts sapphire )
    Wilfried Van replied 13 years ago 3 Members · 4 Replies
  • Jon Kozenko
    August 22, 2013 at 4:24 pm
    Wilfried,
    Are you applying the Sapphire effects inside the RED interface itself? If so, how did you install the Sapphire plugs into RED? Was it manually, or did you use a custom install option? Also, are you on a PC or a Mac? If you’re on a Mac, can you send us a crash report? If you’re on PC, can you forward any error messages that might come up? Send them to me at support@borisfx.com. Send it along and we can take a look. As for the effect you’re looking to use, there might be something within the BCC effects, pre-loaded in Boris RED, that can carry out the desired effect.
    Jon
  • Wilfried Van
    August 22, 2013 at 4:51 pm
    Hi Jon ,
    The system at studio is HPZ820 and dellT7500 , both win7x64.
    Moved the sapphire AE effects ( since they are there anyway ) manually into the boris red plugin folder ( as before with the genarts sapphire 6 , which worked ).
    Boris red crashes fully as soon as you simply try to add one of the
    genarts fx . ( both in standalone red as when red being used as plug-in of , for example vegas pro 11 or 12 )
    Total boris crash , no messsage.
    Just wanted to point this out since that worked with genarts sapphire 6 version .
  • Theo Van laar
    September 26, 2013 at 8:48 am
    Just try the latest update for RED 5: Red 5.4.
    Theo
  • Wilfried Van
    September 26, 2013 at 4:18 pm
    Thanks Theo , same full identical crash with 5.4
