Activity Forums Boris FX RED 5 Wire Remover — Multiple filters cancelled out by the filter on the uppermost track
  • RED 5 Wire Remover — Multiple filters cancelled out by the filter on the uppermost track
    Posted by Carl Alessi on December 12, 2011 at 5:09 pm
    I’m using RED 5 in conjunction with Sony Vegas 11. I’ve applied RED as an event effect to a clip, with the intention of elminating five power lines that are visible in the corner of the frame.
    Applying a single filter in RED was easy, and worked perfectly. Following directions, I tried applying a second filter to eliminate the second wire. Unfortunately, I’m finding out that no matter what I do, the filter that occupies the uppermost track always cancels out any wire remover filters I have in lower tracks–those wires simply reappear in the frame.
    Can anyone suggest a way out of this?
    Thanks in advance,
    Carl
    Boris Yamnitsky replied 14 years, 8 months ago 2 Members · 1 Reply
  • Boris Yamnitsky
    December 13, 2011 at 12:33 pm
    Can’t say for sure what the problem may be, but we’ll try to investigate in our support lab and report back to you.
    Boris Yamnitsky
    BorisFX
