Activity Forums Boris FX RED 5 – Tint keyed out highlights
  • RED 5 – Tint keyed out highlights
    Posted by Jeppe Svendsen on February 29, 2012 at 10:20 am
    Hello
    Can anyone tell me how to tint a layer using a color dipper?
    What I have done is duplicated my video layer. Used BCC Two Way Key to isolate the highlights on the top video layer. Now I want to tint these isolated highlights with a nearby color, so they no longer will be highlights. That’s why I want to use a color dipper.
    Is it possible?
    Jeppe Svendsen replied 14 years, 6 months ago 2 Members · 2 Replies
  • Peter Mcauley
    March 1, 2012 at 4:54 am
    Hi Jeppe,
    If you just want to adjust the highlights, then you can do this without having to use a separate keyer to isolate the highlights from the rest of the image. The color grade / correction filters that are included in RED 5 have a feature called a PixelChooser that performs this task for you.
    • Apply the desired color treatment filter to the clip (perhaps BCC Tritone)
    • Set up the color treatment (probably just adjust the White Color value)
    • Go to the Matte tab in the control panel
    • Set the PixelChooser to View Chosen Pixels
    • Set the Channel to Luma
    • Tweak the settings (most likely the Black Level) until you are only affecting the highlights in the image
    • Set the PixelChooser to On
    • View the result – tweak as necessary
    I hope this helps.
    Peter.
  • Jeppe Svendsen
    March 1, 2012 at 8:49 pm
    Thanks Peter
    I will try that out!
    Jeppe
