Activity › Forums › Boris FX › Red 4 Grids and Guides Aren’t Snapping
  • Red 4 Grids and Guides Aren’t Snapping
    Posted by Larry Asbell on January 31, 2007 at 3:33 am
    I’m turning on Snap to Grid and Snap to Guides but I can’t get anything to snap to them. Tried Red 4 and 4.1. Anyone use these?
    Peter Mcauley replied 19 years, 7 months ago 2 Members · 1 Reply
  • Peter Mcauley
    January 31, 2007 at 5:11 pm
    I just took a look at this and well, it appears as though you have discovered an issue with OpenGl and the snap function in RED. To use the snap function in RED, you will have to temporarily disable the OpenGl preview, which you can do dynamically without having to restart the application. To disable OGL, select Preview>Open GL Mode>Off. Then you should notice that the snap function will operate as expected.
    I hope this helps.
    Peter.
