Red 3GL
Posted by Tim Langston on September 30, 2005 at 11:14 pmAny sign of a fix for field rendering when using Red as a generator in FCP?
TimTim Langston
Cryin’ Out Loud Productions
Fort Wayne, IN
http://www.colproductions.comTim Langston replied 20 years, 11 months ago 2 Members · 3 Replies -
Scott Fisher
October 3, 2005 at 12:16 pmRed will field render any asset added to the wells in fcp or imported into red via the boris UI when using it as a generator in FCP. That was recently fixed. What was not fixed was field rendering of assets created in Red (i.e. text, splines, etc). The easy work around would be to add a slug to your timeline, apply red as a filter to that slug and you should have accurate field rendering and be able to make the comp any size you wish. This is of course just a band-aid solution that needs to get fixed. Unfortunately, I have not heard any news on when that fix will be implemented but at least you can get your work done, however inconvenient it may be.
Tim Langston
October 4, 2005 at 1:59 amYep, that’s what I’ve been doing…just adds an extra step. We paid more than FCP itself, just wish it would work.
Tim
Tim Langston
October 8, 2005 at 6:36 pmLooks like 3.0.4 renders in fields. This is GREAT!!
Thanks Boris,
Tim Langston
Tim Langston
Fort Wayne, IN
