Activity Forums Boris FX Red 3gl Bugs in FCP 4.5
  • Red 3gl Bugs in FCP 4.5
    Posted by Tim Langston on August 19, 2005 at 12:54 pm
    I found a bug or two with Red 3GL in FCP 4.5.
    When applying Red as a generator the screen size is 720 X 427 and can not be changed, also the deflicker setting on fonts does not to work.
    I use Red’s render engine to create a CG page then save as a pict, and the screen size is 720 X 486 like it should be for uncompressed, plus you can clearly see that the deflicker setting works.
    We also have no field rendering for CG rolls when using Red as a Generator.
    Is this fixed in FCP 5, or do we need a point update to Red?
    Tim
    Tim Langston
    Cryin’ Out Loud Productions
    Fort Wayne, IN
    http://www.colproductions.com
    Tim Langston replied 20 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
