Activity Forums Boris FX Red 3GL and 4.1 and multiple processors (mac)
  • Red 3GL and 4.1 and multiple processors (mac)
    Posted by Doug15 on July 26, 2007 at 5:45 pm
    I have Red 3GL and installed it on my MacPro. It works well enough for what I do, but was somewhat dissapointed with the speed. I also noticed it uses just one processor (99% of 400%) with the multi processor button checked. When I uncheck it it uses 101% of 400%. Odd.
    I then download 4.1. Similar speed and similar story with multi processors. Red seems to do a very bad job using more than one processor/core. What gives? And why is 4.1 about the same speed at previewing to RAM as 3?
    I emailed Boris about this last week…no reply.
    Doug Eli replied 19 years ago 4 Members · 4 Replies
  • Boris Yamnitsky
    July 31, 2007 at 2:18 am
    I just ran a test of PTR on a heavy composite project with multiple soft masks and blurs. I opened my processor panel and see about equal load on CPU 1 and CPU 2. I’m running RED 4.1 engine on an Intel Mac laptop with dual core processor. Make sure that all your processors are enabled.
    RED 3 is expected to run much slower on Mac Intel since it is not Intel native and can only operate in Rosetta. RED 3 has some multi processing built in but not to the same degree as RED 4. Hope you’l find this information helpful
  • Doug15
    July 31, 2007 at 2:37 am
    thanks…I tried to test again and not I can’t export from Red3. It just hangs when I hit export to movie. 4.1 works fine, but maybe the 4.1 demo killed my installation of 3. Be nice if Boris would help on this…so far 0-2 contacting their support people.
  • Kieran Matthew
    August 3, 2007 at 5:21 pm
    Hi Doug,
    I also have 4.1 running on a 4-core Mac Pro and get the same results as you.
    Very disappointing to see this happening especially as some effects seem to be just as slow as they were in 3 on a G4!
    K
  • Doug Eli
    August 15, 2007 at 2:45 am
    5 emails, 2 calls…no response. Are they even around?
