Activity › Forums › Boris FX › Red 3.0.4 BFX API Error
  • Red 3.0.4 BFX API Error
    Posted by Steve Pankow on September 19, 2008 at 5:45 pm
    Loaded some new fonts onto my system. When I open Red and attempt to place a new text track onto my comp, I get the following error message:
    BFX API Error
    The specified resource type cannot be found in the image file.
    MenuImp.cpp 65
    Clicking through this error several times produces another error message:
    BFX API Error
    Invalid Menu handle
    MenuImp.cpp 65
    Deleting the .ini file and restarting doesn’t help. Media Composer 2.2.10 runs fine and sees these new fonts, so I don’t know what’s up.
    Steve Pankow replied 18 years ago 2 Members · 5 Replies
  • Peter Mcauley
    September 19, 2008 at 7:17 pm
    Hi Steve,
    Have you tried to see if the RED standalone has the same problem with the font or whether this is isolated to when using RED within the host?
    This type of problem might warrant an email to support to see if they have heard of the issue before. You can contact them here: support@borisfx.com.
    Cheers,
    Peter.
  • Steve Pankow
    September 19, 2008 at 7:24 pm
    No, I’m working with Red as a standalone. I haven’t tried it from within Avid yet.
    I also have 4.2.1 installed on this system and it has no detectable problems with these new fonts.
  • Peter Mcauley
    September 19, 2008 at 7:36 pm
    Hmmm … well if the problem is not apparent in RED 4 then it could be an issue that we fixed with RED 3 and certain types of fonts. RED 3 is so old now that I couldn’t tell you if this is indeed the case though.
    P.
  • Steve Pankow
    September 19, 2008 at 7:44 pm
    It’s old, but it’s what my company has license to. Plus I don’t like the new monochromatic menu scheme. 😉
    FWIW, the font types in the directory (not sure is caps make a difference or not) are:
    TTF, ttf, otf, fon, FON
    with attributes ranging from:
    A, RA and HA.
  • Steve Pankow
    September 20, 2008 at 8:59 pm
    I’ve finally determined that I had all kinds of problems with the font folder containing duplicate entries.
    I rolled back and chose to limit the number of new fonts I installed from this new batch and now things appear to be back to normal.
