Activity Forums Maxon Cinema 4D Rectangle Size Defined By Object Size in Camera
  • Rectangle Size Defined By Object Size in Camera
    Posted by Andrew Doiron on November 1, 2021 at 4:21 pm
    What I’m trying to do is program some objects in such a way that a plain or box will change its size based on the size an object is in relation to the camera.  I posted two different angles of a pill shape showing the desired result, as well as a detailed scene of how I’d like this sort of thing applied to moving vehicles.
    Any help would be greatly appreciated.
    Andrew Doiron replied 4 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
