Activity › Forums › Adobe After Effects › Recreating this effect
Posted by Philippe Gosselin on September 28, 2012 at 4:48 pmHi all,
Please take a look at this video :
https://www.youtube.com/watch?v=i6u2IhJKceo
Now I understand that there is many effects in this montage but my focus is on the switch from picture to picture.
Is that a camera or simply a rotation on the Z axis?
How would you go about recreating a similar effect.
John Cuevas replied 13 years, 11 months ago 3 Members · 5 Replies -
Vishesh Arora
September 28, 2012 at 6:24 pmMr. Gosselin
You were right about the Camera MOve in Z-Axis.
To have better control on camera, Parent it to a Null Object, make it 3D and Apply ” Separate XYZ “.
This will give you Separate controls over All 3 Axis.Also to make a picture look 3D, Here is a tutorial by Andrew Kramer:
https://www.videocopilot.net/tutorials/virtual_3d_photos/
Vishesh Arora
VFX and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.comDemo Reel(3D):
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Philippe Gosselin
September 28, 2012 at 8:19 pmHi Vishesh
All good except how do I apply “separate XYZ”
I am still not sure how to make the transition between the images as seen the example but I’ll keep experimenting.
Vishesh Arora
September 29, 2012 at 5:59 amOh Sorry..!!
Go to Effects and Presets Panel(On the Right hand side in Default Work space) and search for XYZ.
Vishesh Arora
Films RajendraBlog:
John Cuevas
September 30, 2012 at 12:26 pmTo separate the XYZ position parameters, press “P” to open your position property and right click on the word position and choose “Separate dimensions”
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
John Cuevas
September 30, 2012 at 12:57 pmThere are 2 effects in this sequence the Virtual Photos effect and the transitions.
Using a camera might make things more difficult than they need to be for a project like this. Create a null and enable 3D and enable 3D for you photo layers. Move to where you want your transition to start in the timeline and set starting keyframes for position and rotation for the null. Parent picture 1 to the null object. Move 15 frames forward on the timeline and change your Y rotation to 90 and use the null to drag the picture 1 completely off screen.
Now with picture 2 in it’s default position parent it also to the null. Now as you scrub, picture 2 should rotate into place as picture 1 is flying off screen.
Here’s a simple file I made to illustrate the technique:
4727_3dtransitions.aep.zipAlso here’s a link to a similar discussion(along with some project files): https://forums.creativecow.net/thread/2/1023704
