Activity › Forums › Adobe After Effects › Recreating this effect
Posted by Philippe Gosselin on December 4, 2012 at 10:34 pmHi all,
Take a look at these
https://www.vintagetrends.com/thumbnails_/lot/917/917-0042.jpg
https://www.thinkgeek.com/images/products/additional/large/e8c5_aperture_turret.jpg
So a kind of stencil/wash out look where only the main features of a face can be seen, the rest being blown out.
I’ve tried fooling around with Levels and whatnot but it is not the same. So I am wondering if one of you has a better recipe.
Philippe Gosselin replied 13 years, 9 months ago 5 Members · 7 Replies -
Roland R. kahlenberg
December 5, 2012 at 5:26 amEffect>Stylize>Threshold will get you at least half-way there. Tweak the results with some pre-blur. If required, apply Effect>Channel>Invert to invert the BW result.
HTH
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7) -
Tudor “ted” jelescu
December 5, 2012 at 6:47 amRed Giant Toon can be used to achieve this kind of look.
Tudor “Ted” Jelescu
Senior VFX Artist -
Vishesh Arora
December 5, 2012 at 7:35 amPhilippe
Apply Threshold Effect and then Find Edges Effect(you can find both under Stylize).
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.comDemo Reel(3D):
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Kim Segel
December 5, 2012 at 11:43 amSelect your layer.
In top LAYER menu, select AUTO-TRACE
Make sure PREVIEW is checked.
Make sure APPLY TO NEW LAYER is checked.
Adjust settings ’til strokes are where you want them.
Click OK.
When done, turn off original (lower) layer.
Put a new light colored solid under the top layer.
Select top layer again.
Add a EFFECT>GENERATE>SCRIBBLE to that layer
Set it to SCRIBBLE>ALL MASKS
Change it to a dark color.
Reduce parameters until you get the stroke look you want.
A computer once beat me at chess, but it was no match for me at kick boxing. –Emo Philips
Philippe Gosselin
December 5, 2012 at 4:59 pmThanks Fellas!
Kim : Do you know how to reset the values in the Auto-trace window?
I kinda blindly fooled around with them and now I can’t get back to the default values for comparison.
Kim Segel
December 5, 2012 at 7:45 pmWeirdly – I don’t think there is a default (other than lifetime first use values.) Anyone who’s never used AUTO-TRACE want to tell us what they are?
Philippe Gosselin
December 5, 2012 at 8:50 pmA tutorial that seems to corroborate you with you
https://library.creativecow.net/articles/fernandes_nelson/find_edges_mask/video-tutorial
