Activity › Forums › Adobe After Effects › recreating the randomness movement of a butterfly
Posted by David Lieberman on March 7, 2008 at 5:27 pmhello,
I’v got a precomp composed of some 3 layers which make up a butterfly… they are strokes/lines. one layer for the body, and two for each side of hte wings..
is there some known method for creating that random looking movement of a butterly… I DONE MEAN THE FLAPPING OF THE WINGS… i mean the full body movement in the air..the way it moves from point to point in such a snappy and randomized looking way..
thanx for the help.
Chris Heuer replied 18 years, 6 months ago 4 Members · 6 Replies -
Chris Heuer
March 7, 2008 at 7:52 pmI recently made a Butterfly spot. Dan Ebberts helped me out with this expression:
w = wiggle(2,20);
j = wiggle(1.5,95);
z=wiggle(4,90);
[w[0],j[1],value[2]]Copy/Paste it into your Butterfly Pre Comp’s “Position” property. Make sure the Pre Comp is a 3D layer.
You can play with the numbers in parentheses to get more or less extreme movements.
w = wiggle(2,20);
j = wiggle(1.5,95);
z=wiggle(4,90);Remember its (How Often to Wiggle, How Much to Wiggle) so a value of (2, 20) would wiggle 2 times a second, by 20 pixels.
Also, in the bottom line “[w[0],j[1],value[2]]” You need to change the word “value” to the letter “z” if you want the butterfly to wiggle on the z-axis.
Good luck!
Chris Heuer
Freefall FX, LLC -
David Lieberman
March 7, 2008 at 7:58 pmABSOLUTE LEGEND!!! you know any good sources to start teaching myself expressions?
thanks a lot!!
dave
thanx for the help.
Chris Heuer
March 7, 2008 at 8:11 pmYes! Click on “Forums” above. Just under the After Effects Forum is the After Effects Expressions Forum. Lots of great people over there, some from here.
Also goto http://www.motionscript.com
That is Dan Ebberts’ site (He’s one of the expression gurus here). It takes some poking around an a LOT of concentration (for me). But that is the place to really learn.
Chris Heuer
Freefall FX, LLC -
Kevin Camp
March 7, 2008 at 10:37 pmanother good one for the basics is http://www.jjgifford.com/expressions. it’s old (like ae 5.0 old), but he does a very good job of explaining the basics.
i also found that a basic java understanding was useful, i had found this, fromtizag.com, fairly useful for understanding java syntax, java operators, if-else statements and creating loops and arrays, all of which are useful as you get deeper into expressions.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Darby Edelen
March 8, 2008 at 6:27 amHere’s another note on “random” functions. Actually, periodic functions with a bit of random thrown in for good measure =)
If you add several variations of
Math.sin()andMath.cos()together you can end up with some very interesting movements. I did something like this recently to animate a heart beat (not physically accurate, but it came across very well):
fx = 1; //frequency of the sin/cos function for x
fy = 2; //frequency of the sin/cos function for y
fz = 3; //frequency of the sin/cos function for zx = Math.sin(fx * time * Math.PI * 2);
y = Math.sin(fy * time * Math.PI * 2);
z = Math.sin(fz * time * Math.PI * 2);a = x + y + z; //Sum of the sine functions
s = linear(a, -2.5, 2.5, 0, 10); //As the sum of the sine functions ranges from -2.5 to 2.5 range the scale offset from 0 to 10
value + [s,s]; //Add [s,s] (ranges from [0,0] to [10,10]) to the current scale
Here’s a graph of the values that
awould range between in this case:
You could add additional variation by adding some truly random values to the expression. For example, you could use the
noise()function, or you could vary the frequencies based on an Effects > Expression Controls > Slider Control with awiggle()applied.Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Chris Heuer
March 10, 2008 at 3:29 pmOK, I need to take math all over again! Thanks for the tip. I’m gonna need to print out and study this one, but VERY cool! I’m just starting to feel comfotable working with expressions but know none of the language. This is a decent step up for me!
Chris Heuer
Freefall FX, LLC
