Activity › Forums › Adobe After Effects › Recreating Photoshop Wave filter
  • Recreating Photoshop Wave filter
    Posted by Mike Faulkner on October 21, 2016 at 8:32 am
    I want to recreate an effect same as
    Photoshop > Filters > Wave > Type – Square
    Very early versions of After effects had this Photoshop Wave filter, but they changed it
    I know there is a Wave Warp effect in After effects
    But I am interested in using
    Wave > Type: Square option
    Along with Numbers of generators, Wavelength, Amplitude, Scale
    But especially ‘Undefined Areas > Repeat Pixel Edges and Wrap around’
    short of using a very old affects is the a 3rd party plug in or expression I could use?
    Any help appreciated
    Regards
    Mike
    Roei Tzoref replied 9 years, 11 months ago 2 Members · 4 Replies
  • Roei Tzoref
    October 21, 2016 at 12:34 pm
    show a screenshot of the type of effect you want to create and we can offer some workarounds. this probably could be recreated using a displacement map that has this type of texture animating.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Mike Faulkner
    October 21, 2016 at 1:59 pm
    Hi Roei
    here is screen grab I particularly like the random button and the fact you can change parameters over a timeline
    I did think maybe I could do in Photoshop over time
    but last time I checked I couldn’t do it
    basically I have a really old machine and run an ancient version of After Effects, but its stopped working and surely there is a work around out there
    thx
    mike
  • Mike Faulkner
    October 21, 2016 at 2:03 pm
  • Roei Tzoref
    October 21, 2016 at 2:48 pm
    I was thinking show before and after the a full res image. I can’t really tell what is going on but it seems you want the image to be divided in vertical rectangles or squares that are displacing is that correct? you can create a black and white representations of the way you want pixels to shift and use a displacement map to make the video shift it’s pixels in the same way.
    maybe it’s something like this:
    animate the displacement map fractal noise inside and the effect will be animated.
    Roei Tzoref
