Activity › Forums › Adobe After Effects Expressions › recreating a keyboard
  • recreating a keyboard
    Posted by jesse hagen on May 13, 2021 at 12:01 am
    so i am making a template for a phonescreen. now im searching for a slider controlled text animator. and if it even is possible a way to read out what letter is being animated. and make that “key” change color. i am fairly new to this i am just wondering if it is possible
    Filip Vandueren replied 5 years, 4 months ago 2 Members · 1 Reply
  • Filip Vandueren
    May 15, 2021 at 1:36 pm
    It depends;
    if you precomp the keyboard as a composition where every key is lit up at a specific time, you can get the “current” character, and with a timeremap-expression, jump to the appropriate time (you would do a lookup in an array of known times “a=1, b=2;…)
    But things get more complicated with shift-buttons, switching to a different keyboard layout to type in numbers or other special characters that are on screen 2 or 3 of the keyboard interface widget, etc.
