Activity › Forums › Adobe After Effects › Recreating 70s disco funk mv special effects
  • Recreating 70s disco funk mv special effects
    Posted by Nelson Ng on July 21, 2014 at 9:27 am
    I need to recreate some effects for an upcoming video with after effects. The following link is the reference I have been given. https://youtu.be/Lrle0x_DHBM
    How can i achieve:
    – the psychedelic delay effect as seen in 1:04.
    – Glowing and changing colored tint on the trio as seen in 1:44
    – Hypnotic flashes behind the two little person on both sides as seen in 2:35
    – glowing pink outline as seen in 3:21
    John Cuevas replied 12 years, 2 months ago 3 Members · 2 Replies
  • Walter Soyka
    July 21, 2014 at 1:55 pm
    This is all a lot easier if you are shooting elements for chroma-key. If not, you will have to rotoscope them to get the edge-based effects.
    [Nelson Ng] “the psychedelic delay effect as seen in 1:04.”
    Echo effect, plus Colorama.
    [Nelson Ng] “- Glowing and changing colored tint on the trio as seen in 1:44”
    High-contrast levels adjustment, plus Tint effect (with changing colors), plus Unmult.
    [Nelson Ng] “- Hypnotic flashes behind the two little person on both sides as seen in 2:35”
    A few layers, with Fill effect for coloring, plus Blur, plus an Levels adjustment for Alpha only.
    [Nelson Ng] “- glowing pink outline as seen in 3:21”
    Drop Shadow effect or layer style.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • John Cuevas
    July 21, 2014 at 2:19 pm
    You could play with a keying and the echo effect, but this was a DVE effect in the 70/80’s, not really sure how to recreate.
    A glow effect would take care of the first part. Then in this instance some sort of luma key was applied and a the hue was adjusted.
    I’d probably just duplicate the layers, use a key, add a blur effect, then a fill effect.
    Could be done with the above method, or perhaps just a luma key, with just a glow.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
