Activity › Forums › Adobe After Effects › Recreate the La Linea effect in After Effects
  • Recreate the La Linea effect in After Effects
    Posted by Frank Greber on June 18, 2018 at 10:38 am
    Dear Creative Cow community,
    I’m a regular reader of this forum and the posts helped me in many cases – thank you.
    Now I’ve got a question and couldn’t find a solution so far – I hope you that somebody could give me a hint. I know that the classical “La Linea” / “The Line” cartoons by Osvaldo Cavandoli are hand drawn, but recently I saw an ad that features the classical character and looks like 2D animation: Vimeo Ford C-Max. I wondered if there is a method in After Effects to recreate this effect of a character “blending/melting together with the ground”. I would like to animate a simple character in After Effects that melts with the ground and forms an outline – like these examples:
    I thought about a comp with the character and ground inside. Then I would add a kind of Stroke effect onto this comp that draws the line around it. Sadly the stroke effect only works with masks? If someone knows how to recreate this effect or a third party plugin that could help I would be very happy.
    Thank you and kind regards,
    Frank
    Walter Soyka replied 8 years, 3 months ago 4 Members · 3 Replies
  • Eric Santiago
    June 18, 2018 at 2:16 pm
    I don’t believe there is a plugin for this.
    I have tried to find an option for years even as far as using Maya.
    that kind of work is hand drawn in most cases.
    Or some crazy masking in AE.
  • Angie Taylor
    June 18, 2018 at 7:12 pm
    You can use the Paintbrush tool to hand draw this type of animation in After Effects. There are also various stroke-type effects and the Shape tools which offer similar but you wouldn’t get the hand drawn quality with those as you could with the Paintbrush tool.
    cheers,
    Angie Taylor | Creative Cabin Ltd | Linkedin Instructor | Adobe Community Professional
    https://www.creativecabin.co.uk
    https://www.lynda.com/Angie-Taylor/2131450-1.html
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Walter Soyka
    June 19, 2018 at 10:44 am
    [Frank Greber] “I thought about a comp with the character and ground inside. Then I would add a kind of Stroke effect onto this comp that draws the line around it. Sadly the stroke effect only works with masks?”
    I think you’re on the right track.
    Instead of the Stroke effect, though, use the Stroke layer style on your precomp, and set Layer Styles > Blending Options > Advanced Blending > Fill Opacity to 0%.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
