Activity › Forums › Maxon Cinema 4D › recreate safari top sites
  • Adam Trachtenberg
    November 11, 2010 at 5:03 pm
    Try this: https://www.3danvil.com/tutorials/safari_wall.c4d
    That’s an R12 file, let me know if you need it in an earlier version (and general note to anyone reading: please specify Cinema version when you have questions/problems).
    I used a spline wrap deformer because I find it easier to use and more flexible, but it could also be done with a bend or spline wrap deformer.
  • Gon Perdigao
    November 11, 2010 at 5:10 pm
    thanks a lot!!!!
  • Gon Perdigao
    November 12, 2010 at 11:18 am
    just one more question, i have to texturize all the planes with different textures, i’ve made a tutorial a while ago that teach how to do this, i remember that it was with thse shader effector, but i can’t see work it around, can you point me to the right direction please?
    Thanks a lot
  • Adam Trachtenberg
    November 12, 2010 at 3:11 pm
    You would do it using the mograph multishader. Load your images in the shader and then place it on the cloner. Assign the cloner a random effector set to affect color only. Set the random effector to “sorted” mode.
  • Gon Perdigao
    November 12, 2010 at 7:51 pm
    so what i have to do is create a material, in the color chanel choose multishader, and then aply to the cloner, and then with the cloner selected i select a random effector, and in the tab color in select on, and in the the effector tab i select sorted in the random mode, right?
    Cause i don’t have the effect that i wanted, that ir was in every sreen be a differente footage, can you help? or say what i’m doing wrong?
    Thanks a lot for all the help
