Activity Forums Adobe After Effects recreate every second frame using Twixtor
  • recreate every second frame using Twixtor
    Posted by Eran Gindin on July 11, 2007 at 10:14 am
    There’s a trick for improving compressed video (DV,HDV, DVCPRO etc.) to get a better key using Motion Estimation (there’s even a product from The Foundry).
    My question is.
    I want to keep the speed at 100%, but recreate every second frame using Twixtor, based on the previous & next frame.
    How can I set it up ?
    Eran
    Eran Gindin replied 19 years, 2 months ago 2 Members · 2 Replies
  • Shin Kurokawa
    July 11, 2007 at 2:27 pm
    You mean, like stretching it then shrinking it,
    all in one pass?
    Or, prep/precompose a sequence that contains
    half as many frames (i.e. throwing out every other frame)
    then use that (i.e. half the fps of the original) to
    create a new sequence that contains twice as
    many frames (i.e. same fps as the original)?
    Just curious though:
    how would throwing out every other frame
    improve compressed video?
    Having said that, I do this kind of thing
    for cartoon restorations (from film) but
    not for live footage. So I’m just curious…
    -Shin
  • Eran Gindin
    July 11, 2007 at 4:03 pm
    Shin,
    I can’t really tell you why it’s working, but I saw a demonstration of it with good results.
    Thanks for tip. Quite basic when you think of it 🙂
    Eran
