Activity › Forums › Adobe After Effects › Recreate Effect
Recreate Effect
Posted by Chris Barnes on February 4, 2019 at 8:02 pmI need to recreate this wave bulge effect at the start of the following video.
https://vimeo.com/user21238398/review/315304763/e64ff318a7
Any help will be greatly appreciated.
Max Haller replied 7 years, 7 months ago 5 Members · 6 Replies -
Kalleheikki Kannisto
February 4, 2019 at 8:10 pmLink goes nowhere.
Senior Graphic Designer -
Chris Barnes
February 4, 2019 at 8:30 pm -
Richard Garabedain
February 4, 2019 at 9:57 pmreally? 1981 called…they want their special effects back.
Michael Szalapski
February 7, 2019 at 10:23 pmYou don’t need to do it in a precomp anymore if you’re using a newer version of After Effects. You can simply point the Displacement Map effect at the layer with the Fractal effects, blurs, etc. and tell the Displacement map to use the layer with effects and masks and not just the layer source (it’s the second dropdown to the right of the layer picking dropdown).
It makes it easier/faster to iterate on things since you don’t have to keep diving into and out of precomps.– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Max Haller
February 8, 2019 at 4:44 pmyou can probably just use the ripple effect. make the wave height and width like around 100 and increase the radius and then you should be able to start seeing it kick in
