Activity › Forums › Panasonic Cameras › Recovery of MTS files
  • Shaun Cullen
    November 9, 2011 at 11:06 pm
    I realize this is an old topic but I have had this issue myself this week and the way I fixed it was by using a Data Rescue 3 which has an option in it called FileIQ where you can teach it to look for any file type. I loaded a couple of .mts samples in for it to learn the file type and then I was able to pull save all of the files I thought I had lost from a shoot earlier in the week.
    i used Voltaic to convert the files which took ages but got the job done.
  • Annice Ava
    February 6, 2012 at 10:08 am
    Well, I can understand your problem. Losing favorite MTS videos due to accidental deletion or certain formatting or corruption of memory card brings a great havoc. Don’t worry, lost MTS recovery is possible with the help of professional MTS video recovery tool. Using this tool, you will easily recover your lost video files from Sony camcorder in just few simple steps.
    https://www.mtsrecovery.net
  • John Cena
    April 18, 2012 at 6:06 pm
    Recovery of MTS files can be done easily with the help of a recently created backup efficiently. in other cases, If the users have no any backup of lost MTS files, using a third party tool will be very helpful.
  • Patrick Simon
    April 26, 2012 at 6:40 am
    Take a few minutes to try this one. Small but powerful. And very easy to use.
    https://www.recovery-photo.com/
  • Jonathan Shuler
    August 6, 2012 at 2:04 pm
    So I found this thread while spending a panicked evening after a shoot in Andhra Pradesh and only TWO of my 72 clips showed up on my SanDisk. After running Rescue to no avail I ejected the card and put it back in and there they all where…. Strangest thing.
    Virescit Vulnere Virtus
  • Andrés Molina
    August 13, 2012 at 3:57 pm
    Tony,
    I just have the same problem. I was trying with the software thta you recomended but I didn-t found the card, I mean, it did not appears on the computer. How did you use the software to recognize the card?
  • Hugh Murray
    September 26, 2012 at 9:39 pm
    Hi Tony – I stumbled across this thread as the exact same thing happened to me, except with a FS100. Photo Rescue delivered the goods, but the recovered .mts clips are missing heads and tails – just as you described. After all your trial and error sessions, are there specific tricks / settings you would perhaps care to share for Photo Rescue that will enable .mts clip recovery in their entirety? Any suggestions much appreciated…
  • Ashley Walker
    October 17, 2012 at 2:21 pm
    If the data recovery for mac will not work, you can try to recover your data in Windows or Linux system. The recovery of MTS files, you can try Yesterdata data recovery. Once you loss data from sd card or memory cards, you should protect your data from be overwritten by new data. The overwritten will destroy your data completely.
    Source:
    https://www.yesterdata.net
  • David Gary
    March 18, 2014 at 3:02 am
    Since your Panasonic HMC150 digital camera prompt “Check Card” error message, I judge your Transcend 32GB card may be damaged. Typically, this is a logical corruption (non- physical damage). Generally, lost files can be recovered from logic damaged card. You can search “Panasonic photo recovery” or “Panasonic video recovery” on Google to find the right data recovery software. AVCHD Video File (MTS) is a common digital camera video format; most multimedia file recovery tools support recovery of this video format.
    Need to be reminded:
    (1) Once the file is missing, you should stop taking new photos or videos immediately. Otherwise, new pictures or videos may overwrite the lost files. Overwritten files are unrecoverable.
    (2) Before installing and using the Panasonic picture recovery software, carefully read the user manual of the recovery tool.
    (3) Do not buy any data recovery tool, unless it has found the lost files.
    Good luck to you!
Page 3 of 3
