Activity › Forums › Apple Final Cut Pro Legacy › recovery MXF
  • Posted by Marco Civinelli on February 13, 2009 at 5:39 pm
    We have a problem. We made a mistake formatting an hard disk containing footage. The data lost were several “CONTENTS” folders coming from P2, recorded with Panasonic AG-HVX200 videocameras, in DVCPROHD. The hard disk is actually used in Mac OS system. How can we recover the lost data?
    Thank.
    Marco Civinelli
    executive producer Limina srl
    John Fishback
    replied 17 years, 7 months ago
    2 Members · 1 Reply
  • John Fishback
    February 13, 2009 at 9:04 pm
    Don’t do anything to your drive. Don’t write to the drive. Turn off the computer. Then Google Data Recovery and start dialing. This can be very costly, but your best chance of recovery is to stop using the drive immediately. Usually formatting just wipes the directory that tells the OS where each file is located pn the drive. It may not have erased the data. However, if you use the drive, you may overwrite data as the OS thinks the drive is empty.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
