Activity › Forums › Adobe After Effects › recovering from a corrupt file
Posted by David Geist on May 31, 2005 at 4:16 pmIs their anyway to recover any information froma corrupted project file.
David Geist
Ameena Barakeh replied 13 years, 9 months ago 4 Members · 3 Replies -
Mylenium
May 31, 2005 at 4:28 pmTry importing it into an empty project, that sometimes works. Don’t expect to recover all work, though. There’s a good chance something still remains screwed. And next time you might wanna consider incremental save ;o).
Mylenium
[Pour Myl
Jayse
May 31, 2005 at 7:09 pmoften people don’t even save when they have a chance because they say the file never opens and it just crashes AE again.
The secret is to turn the Caps Lock key on. This will prevent AE from trying to process whatever it is that is crashing it – and allow you to turn the effect off – switch OpenGL off – or simply move the Timeline indicator.
Then take the key off and you should be set to go.
This may work in your case – tho I’m not sure ‘how’ ur file is corrupted.
// jayse
Ameena Barakeh
November 11, 2012 at 11:07 amThanks! You’ve saved my file with Caps Lock turned on 🙂
