Activity Forums DSLR Video Recovering Files From Compact Flash Card
  • Recovering Files From Compact Flash Card
    Posted by Ralph Chaney on May 27, 2011 at 7:53 pm
    Can someone recommend software for recovering files from a CF card?
    A free app would be a plus, as long as it’s solid.
    The card has been “erased”, but the files should still be there.
    Thanks much!!!
    -Ralph
    -> Ralph
    Nially Fred replied 12 years, 11 months ago 4 Members · 4 Replies
  • Noah Kadner
    May 27, 2011 at 8:19 pm
    Don’t know of anything free. But the one’s that cost $30+ definitely work- as long as you’ve not added any new shots since the erasure. Is this software for Mac or PC?
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
  • Ralph Chaney
    May 27, 2011 at 8:48 pm
    I’m using a Mac…
    -> Ralph
  • Michael Locke
    May 27, 2011 at 9:22 pm
    Hi Ralph,
    I had good luck with PhotoRec. https://www.cgsecurity.org/wiki/PhotoRec
    Freeware. (thanks again Jonathan Zeigler) https://forums.creativecow.net/thread/280/507#678
    Took about 6 hours to rebuild 14G of files (MVI #’s were gone, but content was same number of files, full duration). My problem was just saving/copying files though, I could view from the card. Lots of support at the site to walk you through the austere interface. Good luck…ML
  • Nially Fred
    September 9, 2013 at 8:10 am
    Can you distinguish if it’s the card that is inaccessible, or just it’s filesystem? I know in Linux, you can access the raw device and try to get you data out of that (which should be possible, since it’s usually just sequentially stored JPEG files). you should try to format the card in Dos prompt, once. If you are unable to format it in Dos prompt also then consult a technician who has experience handling this types of electronic gadgets.
    How to Recover Deleted Photos, Movies from Flash Card
    For CF card:
    How to recover deleted files from cf card with vibosoft cf card recovery
