Activity Forums Apple Final Cut Pro Legacy Recovering a project from Auto Save Vault
  • Recovering a project from Auto Save Vault
    Posted by Lawrence Mcdonough on December 14, 2005 at 7:01 pm
    I posted earlier regarding a project I have nearly completed that has “disappeared” when I try to open it in FCP 5. I trashed the pref.s and they did not bring the project back. However, all the edited clips are in the Auto Save Vault (Thank God) and in the order I edited them. When I open them individually, FCP launches each time and some media is offline and all the audio is offline. This is the first time I am trying to recover a project from the auto save vault. I need guidence on the steps to take in proper order, I want to get it right the first time. I appreciate anyone’s help. Thanks
    Larry
    Lawrence Mcdonough replied 20 years, 9 months ago 2 Members · 2 Replies
  • Tom Meegan
    December 20, 2005 at 6:00 am
    Hi Larry,
    The Auto Save vault saves projects, not clips.
    You specify how often it saves with Final Cut Pro > User Preferences.
    The setting for the auto save vault are on the bottom left of the General tab. Your most recent auto save will most will be your project minus the edits you made from the last auto save.
    I would duplicate (option-drag if you are going to another location on the same disk, just drag if you are going to another disk) the most recent Auto Save to the folder where you keep the projects you are working on.
    Rename it.
    Double click it to open it.
    Final Cut Pro will likely prompt you to attempt to reconnect the off-line files. Choose to do so.
    Choose “Search” and FCP will look for the files. It may not find them.
    If this is so you can use “Locate” and manually search them out. Go to your scratch disk in the “Capture scratch” folder for captured files, and go to where ever you have been keeping your imported files for the other stuff.
    If FCP doesn’t prompt you and opens the project with a bunch of stuff off-line, right-click (or control-click) on the off line files and choose reconnect. Work through the steps above.
    I you need to figure out where your scratch disk is…
    Final Cut Pro > System Settings…
    Your scratch disk is the path to the right of the first “set” button.
    If you don’t remember where a file is…
    View > browser Items > as list
    Expand the browser window so you can see the columns to the right of Name.
    Right click on the dark gray title headings, just to the right of Name.
    Select Show Source.
    This is the path of the file when it was originally captured or imported. Use this to hunt down your media in the reconnecting process.
    Tom
  • Lawrence Mcdonough
    December 23, 2005 at 4:58 am
    Thank You Tom.
    Larry
