Activity Forums Apple Final Cut Pro Legacy recovered files in trash??
  • recovered files in trash??
    Posted by Joe Jennings on July 27, 2010 at 3:49 pm
    Hello,
    I was wondering if someone might be able to give me some information. I have searched “recovered files” in this forum and couldn’t find the info I need. I found some info, but could use a little more specific information.
    There is a “recovered files” folder in my trash. It has two fcp files in it. I CAN open them. I have no idea why these files were recovered. I can then assume that I have done something wrong somewhere. I just have no idea what it was or where to begin, and of course how to fix the problem. and … What do I need to do with these files?
    The files have names that I do not recognize, although when I open the file, it seems to be the same timeline that is in another project.
    Could these files be render files that have been lost in the past?
    I have lost render files before, and couldn’t seem to re-locate them, but I figured I would just render the project again and move on. Is this wrong for me to think and do?
    Here is a little more information: I started working on this project with the intention of it being a fairly small finished project and it has turned out to be big with many project files referencing the media used in the original project file, the project file that I imported all the media in. When I say reference I mean that I created many additional project files that I copied and pasted different parts of the original from. I used more appropriate sequence settings in some of these newer projects.
    If there is a problem, I would like to fix it.
    Any suggestions would greatly be appreciated.
    thanks
    joe
    Joe Jennings replied 16 years, 2 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    July 27, 2010 at 6:30 pm
    If you have autosave enabled, FCP will start trashing old copies. You can specify this in preferences.
  • Joe Jennings
    July 27, 2010 at 7:49 pm
    Cool. Thanks. Good to know.
    I am operating mostly with the default settings of FCP (7). So it probably is autosaving.
    Is it better to keep these files? or does it really matter?
    I usually ‘save all’ from time to time just to be sure work is not lost.
    thanks
    joe
