Activity Forums Adobe After Effects Recover project from non responsive AE CS4
  • Recover project from non responsive AE CS4
    Posted by Martin Fisher on April 18, 2011 at 3:45 pm
    Hi..
    i know its my bad, usually i have autosaving on and dont care to much because of that.. but this time i opened an old AE7 project so it was opened as an untitled project.
    however when i was done and wwanted to put my comp into the render queue i noticed that it was still unsaved so i tried to save it..
    AE just flashed but nothing happened and now i cant click on anything, nothing happens when i do. the task manager doesn’t say its crashed and from time to time some messages like “cant create drawing surface” or something like that pop up..
    i know its probably lost but since AE is still running is there any way to recover it from some temp location or extract it from ram or save it somehow??
    Greg C neumayer replied 10 years, 6 months ago 5 Members · 4 Replies
  • Joseph W. bourke
    April 18, 2011 at 5:05 pm
    I would try importing the project (.aep file) into a new project, and hope for the best. It sounds as if the file got corrupted, in which case the import may not work. If it does, try rendering again, and if there’s a problem, start deleting elements one by one. If you’re lucky, just one of them is the problem. Good luck!
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Dave Irion
    April 18, 2011 at 5:44 pm
    try this script next time:
    https://scott.j38.net/interactive/ae_suicide/
    I’ve used it successfully to save projects that were unresponsive.
  • Walter Soyka
    April 18, 2011 at 5:55 pm
    If you are running AE CS3 or higher on Mac OS X, AE Suicide [link] might help.
    If you are UNIX-inclined, you can do the same thing this script does on the Terminal by using “kill -SEGV xxx” on the main AE process. (You can find its process ID [PID] to replace xxx with Activity Monitor.)
    Either way, it will force the application to close, and the AdobeCrashDaemon will work its magic and try to save out a copy of the project.
    Walter Soyka
  • Greg C neumayer
    March 3, 2016 at 8:52 pm
    This just saved my bacon! I got an hour in and forget to save my project!
    Worth the $10.
