Activity › Forums › Panasonic Cameras › recover P2 e series card?!
Posted by Jake Nabutovsky on January 24, 2011 at 5:15 amAnyone knows how to recover formated card (16gb) from HPX170p?! didnt write anything over it, i think, tried Disk worrior no good tried a couple of progs from panasonics support site no good either need that footage ASAP! There is gotto be a way…
Jake Nabutovsky replied 15 years, 7 months ago 4 Members · 7 Replies -
Jeremy Garchow
January 24, 2011 at 10:06 pm[jake nabutovsky] “Disk worrior no good tried a couple of progs from panasonics support site no good either need that footage ASAP! There is gotto be a way…”
Most likely you have to send it in.
Jeremy
Chris Tompkins
January 25, 2011 at 12:09 amI think if you just deleted the files they are still there and just the pointer is gone. If you format then it’s all gone gone.
I could be wrong but this is how I understand it.Chris Tompkins
Video Atlanta LLC -
Jeremy Garchow
January 25, 2011 at 12:34 amWell, kinda. It depends on how you formatted. If you zeroed the disk using p2 Formatter, the yes, it’s gone. If just a quick format and didn’t reuse the card, the directories/forks are erased but the Media is still on the card, and could be hard to recover. Disk warrior isn’t enough. Try DriveSavers.
https://www.drivesaversdatarecovery.com/
Jake Nabutovsky
January 25, 2011 at 1:56 amthanx man i’ll try, but looks like best way is to send it in!
Jeremy Garchow
January 25, 2011 at 4:01 amYes, you have to send to drive savers anyway.
They are awesome, by the way. I have used them on other hard drives, but not p2. Make sure they can handle it. My guess is they can.
Jan Crittenden livingston
February 1, 2011 at 9:55 pmYou could also contact Panasonic Service in the NJ office. They may charge you but I have seen them pull back a formatted cards previous recording. Email off line and I will give you the contact.
Best,
jan
Jan Crittenden Livingston
Product Manager, AVCCAM, AG-3DA1, AG-AF100
Panasonic Broadcast & TV Systems -
Jake Nabutovsky
February 1, 2011 at 10:18 pmThanx everyone panasonic said they’ll do it for free, so mo need to o crazy))
