Activity Forums Panasonic Cameras Recording with PanasonicAGHVX200
  • Recording with PanasonicAGHVX200
    Posted by Luis otavio Feldens on January 10, 2008 at 8:56 pm
    HI there,
    I’m Buying a PanasonicAGHVX200 and I need to know if I can record/playback Full HD(1920×1080) using MiniDV tapes, and not through P2 card.
    Thank you
    Luis O Feldens
    James Carroccio replied 18 years, 8 months ago 5 Members · 5 Replies
  • Noah Kadner
    January 10, 2008 at 11:18 pm
    100% negative. That was an easy one. 🙂
    -Noah
    Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the HD Survival Guide!
    https://www.callboxlive.com
  • Luis otavio Feldens
    January 10, 2008 at 11:52 pm
    OK, and if I use P2 cards, what is the easiest and not to expensive solution to transfer from the P2 to iMAC or MacBookPro.
    Luis O Feldens
  • Emre Tufekci s.o.a.
    January 11, 2008 at 12:59 am
    Your camera and a usb cable or a dueladapter. Another easy one. (Virtual high 5 to Noah)
    Emre
    http://www.productionpit.com
    Boxx Tech PC, dual-dual AMD 2.0,4BG ram,Avidexpress HD w/Mojo,UVW-1800,DSR-25, Adobe Premium CS3.Steadicam OP/Owner.
    “Creative cow is udder madness.”
  • John Kersten
    January 13, 2008 at 10:28 pm
    Luis-
    USB is yes the simplest way to do it, but if you’re recording 1080 you’ll find it’ll take a long time to dump the footage over USB, and keep in mind you’ll be unable to use your camera while this takes place.
    The most efficient way to do P2 (IMO) is to use the biggest cards you can find so you can shoot all day and then transfer everything later, although this is more critical for situations where you can’t easily bring a laptop/hard disk around, i.e. documentary/news.
    You can rent the highest-capacity cards for not too much money, but think about getting a couple of 4 or 8gb cards to have on-hand since you’re buying the camera. Serious investments in P2 are probably not worth it until there are affordable 64 or 128gb cards.
  • James Carroccio
    January 17, 2008 at 2:06 am
    hello john,
    im a final year film student and was wondering if investing in the panasonic hvx200 would be wise. i hear it is a great camera.
    do u know when it came out?
    do u think itll last me five years?
    does it shoot true hd?
    i would appreciate ur advice. thank u in advance.
    JimmyJames
    film student
