Activity › Forums › Apple Final Cut Pro Legacy › Recording with 2 mics
Posted by Scott Davis on February 24, 2008 at 6:12 pmIs there a way using FCP or STP to use two USB mics at the same time? I am recording a podcast and they want each person mic’d independently. I have FCS 1 running on a MBP.
Rennie Klymyk replied 18 years, 7 months ago 5 Members · 10 Replies -
Warren Eig
February 24, 2008 at 6:15 pmThe easiest way would be to use a mixer. Each mic would go into its own channel and then you send the feed from both mic into the program you want to use.
Warren
Warren Eig
O 310-470-0905email: warren@babyboompictures.com
website: https://www.babyboompictures.comhttps://www.atomfilms.com/af/content/knitwits
https://www.atomfilms.com/film/family_xmas.jsp -
Scott Davis
February 24, 2008 at 6:29 pmYeah but that would mean I couldn’t use USB mics. And then how would you get this into your machine. I will be doing it with my laptop because it is at their workplace. So I need it simple if possible.
Scott Davis
Ernie Santella
February 24, 2008 at 6:50 pmSimple…
Get one of these. 2 channel USB powered Mic Preamp. Perfect for location recording.
https://www.m-audio.com/products/en_us/MobilePreUSB-main.html
Scott Davis
February 24, 2008 at 7:13 pmLooks great except, again, it would require buying the pre-amp, and 2 regular mics. This is a simple podcast and I have one USB mic allready. The job isn’t worth it if I have to invest in $500+ worth of gear.
Scott Davis
Ernie Santella
February 24, 2008 at 7:19 pmOoops, I think I mis-read your post. You just want to buy one additional USB microphone and then run two USB mics into your laptop.
When you hookup one mic to a Mac, it only allows one input source at a time. Now, I have read that you can use some music software like Cubase that allows two USB mics at the same time. Do a search on that. (But it still requires purchasing a piece of SW)
Good Luck!
Scott Davis
February 24, 2008 at 7:31 pmExactly. Its a quick and simple job for a friend. The reason they want 2 mics is they thought the first one I did was “hollow sounding” which it was. Now I am no audio/recording guy. I have a Blue Snowball and placed it inbetween the 2 speakers (who where in a conference room with lots of hard surfaces). Is there a better micing practice for a situation like this?
Scott
Scott Davis
Bouncing Account needs new email address
February 24, 2008 at 8:31 pmThe best possible technique is using one good quailiy mic per person, properly placed on a boom (or clipped onto the talent properly, in the case of a lav mic.)
Then, each mic to be recorded on a separate track (for adjustment in post)
or mixed “live” by a competent, attentive audio operator. -
Rennie Klymyk
February 25, 2008 at 7:32 pmMy 1st thought was adding a camera in the middle with 2 mic inputs and pass through to the computer. but then you need 2 xlr mics.
Now why don’t they make “Y” splitters for USB mics? Guess it’s not possible.
I wonder what would happen if you connected 2 USB mics to a USB hub and then to the computer?
“everything is broken” ……Bob Dylan
February 25, 2008 at 8:47 pm -
Rennie Klymyk
February 25, 2008 at 10:11 pmOK, now I understand this warning.
https://groups.imeem.com/g2Fpiz0V/video/s0Pqo1DZ/apple_power_mac_g4_commercial_commercials_video/
