Recording VO in PP CS6
Ok, so I thought that I would do something in PP that I used to do in FCP all the time. Record a piece of temp VO. Plugged in the mic set up the prefs for audio HW and proceeded. Failure, lots of problems, audio was distorted and played back at twice the speed, Hmmm I looked at the audio clip it was 41000hz and the timeline was 48000hz Ah ok thats why its playing back fast, si looked for a preference to change the audio recording settings to 48000hz, could not find any way of doing that. Ok so I then made a timeline seq that had 41000hz audio I thought that would work, but no. This time as soon as I went into record I got a horrendous noise that just kept getting louder and louder and I had to switch off.
At this point I abandoned PP and went over to the old faithful FCP 7 open it it up turned on the VO recording pressed record and hey voila a perfect recording which I had to export as AIFF and then import into PP. WHY COULD I NOT DO THIS IN PREMIERE? WHAT WAS THE PROBLEM?
Are there any knowledgeable persons out there that can help me.
