Activity Forums Apple Final Cut Pro Legacy recording timeline playback
  • recording timeline playback
    Posted by Maurik De ridder on February 8, 2006 at 2:10 pm
    greatings…
    i have a problem recording my sequence back to tape…
    i’m using fcp 5.0
    and have canon dm xm2 camera with firewire
    when i hook up my camera, set it to vtr-mode and press record
    and let my sequence play from in to out, all i record is black
    not a frame of my sequence is recorded
    can anyone help me out with this, suggestions
    (i have ‘external video’ set to ‘all frames’ and in audio/video settings put ‘playback output’ set to ‘firewire’)
    thanks
    maurieketje
    Shane Ross replied 20 years, 6 months ago 2 Members · 1 Reply
  • Shane Ross
    February 8, 2006 at 7:07 pm
    #8 External Monitor Viewing.
    Shane’s Stock Answer #8:
    A simple path is mac > firewire > camera or deck > rca cables > tv
    Then start up your camera and tv, then open fcp.
    Then go View > External video > all frames
    Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
