Activity Forums Canon Cameras Recording through XH-A1 to computer
  • Recording through XH-A1 to computer
    Posted by Mike Van veen on December 21, 2010 at 5:45 pm
    I’m trying to capture some footage of a wedding my sister went to. It was recorded on a Sony camera in Mini DV format. For some reason, my XH-A1 won’t playback the tape properly, it’s very jittery, etc. I have also tried it in a JVC camera with the same results. However, my parents little Sony Handycam plays the footage just fine.
    The issue is FCP won’t recognize their camera. I am trying to record through my XHA1 onto FCP. I know I have done this before with a VCR, but I can’t remember how. I have the settings on AV->DV and the input from the Handycam into my A/V port on the back of the camera. I press Pause/Record on my remote, but nothing. Am I missing a step?
    Mike
    Bob Dix replied 15 years, 7 months ago 3 Members · 4 Replies
  • Brian Louis
    December 21, 2010 at 6:43 pm
    [Mike Van Veen] “XH-A1 won’t playback the tape properly, it’s very jittery,”
    What model of sony cam was it recorded on? was it recorded in the LP mode?
  • Mike Van veen
    December 21, 2010 at 6:52 pm
    Unfortunately I don’t know what it was recorded on. My sister hired someone and then just got me the tapes.
    Again, I don’t know if it was LP, but does that matter for playback? And why would it play in one camera, but not two others? Thanks for the insight though. I will do my best to check.
    Mike
  • Brian Louis
    December 22, 2010 at 9:16 am
    [Mike Van Veen] “I don’t know if it was LP, but does that matter for playback? And why would it play in one camera, but not two others?”
    You can tell if its LP by the lenth, if they are approx 60min length on 60min(up to 63 depending on the tapes) they are regular, if 80min long on 60min tapes they are LP, reason is DV LP tapes are notorious for playback problems when played back on decks or cams other that the original and sometimes problems even on the original. Also the original cam could have alignment problems which could cause it to act like a LP tape, I would see if I could borrow or rent a sony DV camera or deck and try to playback on it, sony’s have a very good servo system that sometimes can keep a bad tape on track.
  • Bob Dix
    January 7, 2011 at 10:38 pm
    Mike,
    It could be the codec, is it HDV/mpeg-2 as is the Canon otherwise the XH-A1 will not play it and even DV can be a problem depending on your camera settings ?. I use HDV/mpeg-2 1440 x 1080 only. Sony would not talk to Panasonic originally and that was a joint venture ?
    Freelance Imaging & Video
    AUSTRALIA
