Activity Forums Blackmagic Design Recording the DVI out from a PC
  • Recording the DVI out from a PC
    Posted by Gary Jones on August 7, 2012 at 2:48 pm
    Hi all,
    Bit of a longshot here, but:
    If you set the graphics card output to 1920×1080 at 50Hz, converted the DVI to HDMI, could the Hyperdeck Shuttle record the signal? I am trying to solve a problem of recording the desktop (under linux, mac, & windows) without putting a strain on the machine.
    – Gary Jones
    Richard Freemantle replied 14 years, 1 month ago 3 Members · 2 Replies
  • Aleksander Steffensen
    August 8, 2012 at 8:29 am
    You would have to output interlaced for it to work in that resolution. Here is a list of supported formats, look under the “HD format support” section: https://blackmagicdesign.com/products/hyperdeckshuttle/techspecs/
    If you need progressive video, you can’t do 50 Hz.
    Steffensen Multimedia
  • Richard Freemantle
    August 9, 2012 at 1:53 pm
    Hi Gary,
    My solution to this problem was:
    H264 Pro-Recorder +
    GFX Card (NVidia) with HDMI out (nb. DVI>HDMI was v.problematic) +
    MX Light
    This allows me to record the output of the GFX card at 1920x1080p @ 60Hz on the same machine with a CPU overhead of about 2-4%. The H264 Pro-Recorder records at upto 30Mbps h264/aac, which although compressed is enough for my purposes (tutorial videos).
    In fact, I wrote MX Light initially to solve just this problem.
    MX Light is currently windows only, so for recording linux/mac desktop output you would need to run MX Light in a VM or use a second machine. nb. You dont need a powerful machine to record with, as the encoding is done in hardware & the data rate is low enough for normal/cheap hard drives.
    Hope this helps.
    Cheers,
    Rich
