Activity › Forums › Adobe Audition › Recording straight into Adobe Audition CC
  • Recording straight into Adobe Audition CC
    Posted by Mp Nunan on March 9, 2014 at 1:16 am
    Hello — I have both Adobe Audition CS6 and Creative Cloud.
    It used to be, on my Windows computer, I could simultaneously record from a line-out or headphones out on a camera, or audio-recorder, into the line-in on a laptop straight into Adobe Audition (then called “Final Edit”) in real-time.
    My MacBook Pro is from 2013. (The bottom computer in this pic.) https://images.macworld.com/images/article/2012/06/leftside-283840.jpg
    NOW, my Adobe Audition doesn’t want to record from a line-in / mic-in jack. If it does, it’s very, very low levels.
    Yes, I have the “System Preferences” under Sound set to “line in” and “audio-line in port.”
    Where can I adjust levels?
    Am I missing a setting somewhere?
    Thank you in advance. – MP
    Mp Nunan replied 12 years, 6 months ago 2 Members · 2 Replies
  • Joseph W. bourke
    March 13, 2014 at 1:35 pm
    You don’t say anything about the sound card in your MacBook Pro, so I would assume that they use an onboard card, but there should be some sort of control panel for levels going in to and out of the card.
    A microphone input is typically a very low level signal, and is mono. A line in will be expecting a much higher input level, and will usually be stereo.
    The sound card should have an additional pre-amp stage for the mic to bring it up to line levels. Here’s a rundown on the internal card (probably Intel):
    https://discussions.apple.com/message/9312193#9312193
    Can you adjust the input levels on the device outside the MB which is sending the audio?
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Mp Nunan
    March 13, 2014 at 5:04 pm
    Thank you for the reply.
    Messing around with this some more, I’m able to record a mono recording from a line-out with my Ipod, for example (clearly this is not a sound-card issue.)
    However, I’m unable to monitor the audio through my computer’s headphones out at the same time (bearing in mind that I have a separate line-in.)
    Any idea?
