Activity Forums Adobe Audition recording stops itself and horrible beeping!
  • recording stops itself and horrible beeping!
    Posted by Ian Pollard on March 11, 2010 at 10:01 pm
    i tried to record a live session tonight with only 10 inputs.
    after 18 minutes it stopped recording (the wave boxes disappeared), but the cursor kept moving (like when you press play).
    I checked that there was enough room (there was 50GB free), i checked that the screensaver or anything else was not running in the background (nothing interfering at all)!
    not only this, but every so often a “beep” would be recorded too, on a range of tracks.
    i’m using the m-audio fast track ultra 8r and ASIO4ALL driver (as I’m also using another USB soundcard).
    any ideas?
    Ian
    Steven Talley replied 16 years, 6 months ago 2 Members · 1 Reply
  • Steven Talley
    March 14, 2010 at 7:26 pm
    Is there a reason your not using the ASIO drivers from M-Audio. (Probably so you could use the second audio device)I understand that.
    Using 2 different types of audio capture devices might be causing timing problems leading to the crash.
    Some things that may help would be to have more ram memory while using a 64 bit OS. A second hard drive for data only.
    I remember hearing that the M-audio Ultra 8 device can be used with a second Ultra 8 to record up to 16 inputs at once.
