Activity › Forums › Apple Final Cut Pro Legacy › Recording Stopped due to Dropped Frames during Log and Capture
  • Recording Stopped due to Dropped Frames during Log and Capture
    Posted by Jonathan Reed on June 8, 2015 at 11:10 pm
    I was doing a log and capture when a warning came up of “Dropped frames” and fcp ended my capture… I also can’t find the video. Isn’t that already saved? did I lose it forever?
    JR
    David Roth weiss replied 11 years, 3 months ago 2 Members · 1 Reply
  • David Roth weiss
    June 8, 2015 at 11:30 pm
    Tough to tell exactly what happened or where the files are without a lot more info… However, it certainly sounds as if you inadvertently directed the capture to your boot drive, which is probably not fast enough to capture without dropping frames.
    You can search the boot drive using Spotlight, filtering by file extension, date, etc., however, they most likely won’t be useable due to dropped frames.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
