Activity Forums Audio recording sound for the Red One
  • recording sound for the Red One
    Posted by Elliott Klein on July 18, 2011 at 6:25 am
    im doing sound on a short film shooting on a red one camera next month
    which will give me the best results? do i go from the mixer via a breakaway cable to the red or record it separately on my H4n and get them to sync it later in post.
    and also if im recording to the H4n, would i go straight in to the H4n from the boom mic or go though a Shure FP33 mixer 1st then in to the zoom
    Noah Kadner replied 15 years, 2 months ago 3 Members · 2 Replies
  • Brian Reynolds
    July 18, 2011 at 10:51 am
    Why not do both?…. record straight to the RED camera with a breakaway cable and also do a backup recording on the H4n.
    If they use the RED audio it will save syncing time.
    Feed the H4n from the tape out socket of the FP33 mixer.
    I have used my H4n directly on a boom pole with a case made by “STRUT cases” this set up is great for a compact recording unit.
    https://www.strutcases.com/What_Camera__What_Case_/Audio/audio.html
    The difference between Knowledge and Wisdom is… Knowledge is the knowing of facts…. Wisdom is the sensible application of good quality knowledge…
  • Noah Kadner
    July 18, 2011 at 4:29 pm
    We do both. On board is a fine enough backup but the controls leave a lot to be desired. You’ll likely stick with your H4N audio instead.
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and GoPro HD Hero.
