Activity › Forums › Adobe Premiere Pro › Recording setup and editing advice.
  • Recording setup and editing advice.
    Posted by Irving Walker on December 11, 2016 at 1:48 pm
    I am soon to take on the filming for a band and hope to make it successful and do many more. I know a bit about filming and basics of prem pro but there is still a lot to learn and get right before the shoot. This is what I have so far…
    2x GoPro hero black
    2x Panasonic camcorders 1080p
    1x Sony DSLR 1080p
    1x iPhone 7 plus with DGI go gimbal
    Location will be a barn or warehouse so hopefully a decent amount of natural light inolved.
    What I am thinking of purchasing….
    Basic set of softbox lighting
    A tripod jib
    I am aware of a few things to consider…
    Insert four drum hits at start of track for camera syncing
    Try to get cameras to shoot as neutral colour as possible.
    What I am thinking….
    Shoot all in 16:9 and add the black bars in post to create a cinema scope effect I am looking for. Not all cameras I have can shoot in other formats so this seems the best option.
    There is some advice I am looking for…
    One camera will be front and centre for the ‘main shot’. Should this be a GoPro in 4K so I can crop in and create pans etc in post or would a GoPro not be as good for this and I am better using the dslr in 1080p? Or maybe use both for same shot and use GoPro for cropping in?
    Any tips at all for getting all the cameras looking the same. This is my biggest worry as colour correction and grading is not something I have experience of.
    There will be multiple takes with close ups etc so I want to make sure things are organised well. Once I add all the media to prem pro should I use a multi cam edit? The videos I have seen on this usually only have 2-3 shots to work with and I am wondering if with 10+ potential shots is this the best method?
    It seems to create one track once you do the multi edit, but what if I change my mind on some of the shots. Can I go in and re-edit certain sections?
    I think I have covered most things but if I have missed important info then let me know.
    All and any advice for a shoot like this is massively appreciated.
    Alan Lloyd replied 9 years, 9 months ago 2 Members · 2 Replies
  • Irving Walker
    December 11, 2016 at 5:22 pm
    Ah yeah. I do have filmic pro app where you can set things like aspect ratio and fps, along with white balance and a few other bits. Going to go for 25fps throughout I think as this seems fairly standard and not sure a high fps will look ‘right’.
  • Alan Lloyd
    December 11, 2016 at 5:40 pm
    Unless all cameras will also be recording audio locally you might consider adding a single burst of a photographer’s strobe at the beginning as well. It will be on only one frame and make (visually) syncing up camera rolls rather simple.
