Activity Forums Sony Cameras Recording RAW Sony FS5 mii
  • Recording RAW Sony FS5 mii
    Posted by Hal Beery on December 2, 2022 at 5:38 am
    I’m new to the FS5mii. In-camera recording all good except RAW. What did i miss in the setup? what to check??? thanks!
    Rob Neidig replied 3 years, 9 months ago 2 Members · 1 Reply
  • Rob Neidig
    December 2, 2022 at 8:11 pm
    Page 71 of the manual.
    It’s in the REC/OUT SET menu. You first set that you want to use RAW, then choose what frame rate you want.
    Note that if you really have the original FS5 (without the Mark II), then you cannot record in RAW without paying for an upgrade.
    Hope this helps.
